seanmcdaid
Mar 22, 2020Follower
Nighthawk C7000
FYI, I'm not very experienced with this stuff at all. I recently got a Nighthawk C7000 router to replace my old comcast one. The wifi itself runs pretty well there isn't too much to complain about, b...
michaelkenward
Mar 23, 2020Guru - Experienced User
That's a cable modem/router. What else is on your network?
seanmcdaid wrote:
Also I should probably mention I use ethernet and TP link powerline adapters to get the connection to my bedroom where my pc is.
Did you reset these and set them up again from scratch when you replaced the modem/router?
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & Routers
