duffz
Aug 28, 2023Aspirant
Nighthawk C7000V2 - Google TCL TV Connects, but won't get Internet Access, while other Devices will.
I have a Nighthawk C7000v2 - https://www.netgear.com/support/product/c7000v2 Firmware Version V1.03.08 Hey Guys, Maybe someone can help, I am going crazy trying to get my new Googl...
Aug 28, 2023Guru - Experienced User
What channel configurations are currently set on the router?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- duffzAug 28, 2023Aspirant
Startup Procedure Procedure Status Comment Acquire Downstream Channel 627000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode IPv6 Only ipv6Only(1) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 21 627000000 Hz -3.2 dBmV 37.8 dB 0 0 2 Locked QAM256 1 507000000 Hz -0.4 dBmV 38.8 dB 0 0 3 Locked QAM256 2 513000000 Hz -0.9 dBmV 37.5 dB 0 0 4 Locked QAM256 3 519000000 Hz -0.5 dBmV 37.3 dB 0 0 5 Locked QAM256 4 525000000 Hz -1 dBmV 39.3 dB 0 0 6 Locked QAM256 5 531000000 Hz -0.7 dBmV 38.8 dB 0 0 7 Locked QAM256 6 537000000 Hz -0.5 dBmV 37.2 dB 0 0 8 Locked QAM256 7 543000000 Hz -1.2 dBmV 37.1 dB 0 0 9 Locked QAM256 8 549000000 Hz -1.3 dBmV 35.6 dB 0 0 10 Locked QAM256 9 555000000 Hz -1.7 dBmV 37.5 dB 0 0 11 Locked QAM256 10 561000000 Hz -1.5 dBmV 38.3 dB 0 0 12 Locked QAM256 11 567000000 Hz -2.5 dBmV 38.7 dB 0 0 13 Locked QAM256 12 573000000 Hz -2.7 dBmV 38.6 dB 0 0 14 Locked QAM256 13 579000000 Hz -2.7 dBmV 38.2 dB 0 0 15 Locked QAM256 14 585000000 Hz -2.7 dBmV 38.5 dB 0 0 16 Locked QAM256 15 591000000 Hz -3.2 dBmV 37.3 dB 0 0 17 Locked QAM256 16 597000000 Hz -3.4 dBmV 37.1 dB 0 0 18 Locked QAM256 17 603000000 Hz -2.7 dBmV 37.8 dB 0 0 19 Locked QAM256 18 609000000 Hz -2.8 dBmV 37.4 dB 0 0 20 Locked QAM256 19 615000000 Hz -2.9 dBmV 38 dB 0 0 21 Locked QAM256 20 621000000 Hz -3.5 dBmV 37.2 dB 0 0 22 Locked QAM256 22 633000000 Hz -2.7 dBmV 37.2 dB 0 0 23 Locked QAM256 23 639000000 Hz -3.1 dBmV 37.6 dB 0 0 24 Locked QAM256 24 645000000 Hz -2.8 dBmV 38.2 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 5 5120 Ksym/sec 35600000 Hz 45.5 dBmV 2 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 43.5 dBmV 3 Locked ATDMA 6 2560 Ksym/sec 40400000 Hz 47.8 dBmV 4 Locked ATDMA 2 5120 Ksym/sec 16300000 Hz 42 dBmV 5 Locked ATDMA 4 5120 Ksym/sec 29200000 Hz 44 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV EVENT LOG:
2023-8-28, 14:55:44 Notice (6) WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INTERFERENCE 2023-8-28, 14:52:29 Notice (6) WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:2) - Reason:INTERFERENCE 1970-1-1, 00:00:47 Notice (6) Overriding MDD IP initialization parameters; IP provisioning mode = IPv6 1970-1-1, 00:00:41 Notice (6) WiFi Interface [wl1] set to Channel 48 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:41 Notice (6) WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT 1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:44 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:01:5c:8e:a6:84;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:38 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2023-8-22, 10:41:28 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:01:5c:8e:a6:84;CM-QOS=1.1;CM-VER=3.0; 1970-1-1, 00:00:46 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:01:5c:8e:a6:84;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:39 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:42 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:01:5c:8e:a6:84;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:00:37 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2023-8-21, 20:34:17 Critical (3) Resetting the cable modem due to docsDevResetNow 1970-1-1, 00:00:38 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 2023-8-21, 20:23:13 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:01:5c:8e:a6:84;CM-QOS=1.0;CM-VER=3.0; 2023-8-21, 20:23:04 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:01:5c:8e:a6:84;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:42 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:41 Critical (3) No UCDs Received - Timeout;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:22 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:21 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:20 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:19 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:18 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:17 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:16 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:15 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:14 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:13 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:12 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:02:10 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:01:50 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:01:48 Critical (3) No UCDs Received - Timeout;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:01:31 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:01:19 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:01:18 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:01:09 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:01:08 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:01:07 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; 1970-1-1, 00:01:06 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=cc:40:d0:c3:6b:58;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; Thank you for the help. Please let me know if I didn't paste that correctly.
WIFI neighbors, there are about 2-3 neighbors that show up with medium strength. I have also tried setting up a guest network to connect to, but it also still has no internet.
- FURRYe38Aug 28, 2023Guru - Experienced User
Good paste.
Power looks ok. With in specs.
I see lots of Criticals in the event log that can point to line issues from the ISP.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?- duffzAug 28, 2023Aspirant
2-3 Wifi neighbors.
The strange part is that everything else in my house connects fine. Its only this new TV I am having trouble with. Thinking about returning it as I don't think its a line, or wifi problem with everything else working fine.
I've tried channel 6 & 11 on 2.4 Ghz, and 48 on 5 Ghz. Both give the same error.
I have my TV sitting right next to the router. My computer is about 10 feet away plugged directly in, and I have 400 down. But still won't give access to my TV.
I still have a rented Xfinity Router sitting around, and I am going to try swapping that back in this evening to see if it fixes it. If so, I am at a loss, and might just return the TV, as I don't want to buy a new one, or use their rented one.
