krajthilak2
May 19, 2022Tutor
Nighthawk c7000v2 connection drops with Palo alto Global Protect
Hello, I recently purchased Nighthawk c7000v2 and I use Global Protect vpn for my home office connectivity. This setup was working fine for couple of weeks and now all of a sudden, I can see connect...
- May 19, 2022
Thanks for the response. I think the issue got fixed today morning after I had a call with NetGear support. They asked me to change the static IP address of DNS (Primary, secondary and tertiary) to a different one and so far it has remained stable. I will monitor this further and update the post.
May 19, 2022Guru - Experienced User
do you have a screensnip of the cable connections page and event logs?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
- krajthilak2May 19, 2022Tutor
- krajthilak2May 20, 2022Tutor
Issue is now resolved with the fix mentioned in previous reply.
- plemansMay 20, 2022Guru - Experienced User
You can mark it solved then if you'd like
