kcdubya's avatar
kcdubya
Nighthawk C7000V2 Connection issues
I have a Nighthawk C7000V2.  Periodically and seemingly randomly one of my wi-fi devices cannot connect. It may be a different device each time.  When I have seen this problem occur I have 32+ devices connected split across the 2 bands.  Most devices are on the 5G band, and there are typically 25 or 26 devices on that band.
My understanding is that I can have up to 32 wi-fi devices on each band, so it does not appear that I am hitting the 32 connections per band limit. Is there some other limit that could be causing this?
Rebooting the wi-fi device does not fix the problem, but rebooting the C7000V2 does.  However, I assume that is because the previously blocked wi-fi device is connecting after the reboot before some other device was able to reconnect.
Note, in the interest of full disclosure, I also have 2 EX8000 Mesh Extenders that are part of the network. However, I am sure that the blocked w-fi device is trying to connect directly to the C7000V2 because I brought the device right next to the C7000V2 and rebooted it. Therefore, I wouldn't think the EX8000s are a factor.
Any thoughts on what may be causing the problem?  What else should I look at?
