Rengel134's avatar
Rengel134
Follower
Feb 16, 2021
Nighthawk c7000v2 download speed
I am running a Netgear C7000v2 modem router, directly connected to the wire. Firmware version: V1.02.09. thE ISP controls the  firmare version updates. ISP: Spectrum in Rochester, NY, although I, personally. am pretty far out into the contry. I have a laptop running Windows 10 hardwired into the device. and I am using it for all my testing
I was just notified thet I have been upgraded to 200Mbps service from 100Mbps service by Spectrum. The best speed I can get seems to be about 120Mbps.
Had a Spectrum Tech at the house and has tested the line at 1000 Mbps coming into my device but seems to be trhottling it to about 120Mbps max.
I have been trhough all my settings on this thing looking for any way to adjust it; there isn't even any way for me to manage any QOS settings on it. Spectrum tech told me it's my device [personal device, not rented from provider] and just left.
Very frustrated. Any suggestions?
1 Reply
  • plemans's avatar
    The C7000 won't pull gigabit through spectrum so I'm not sure how the tech said he was getting that on the c7000.
    Did you try a factory reset and install?
    Make sure to leave qos, access control, traffic monitoring, and parental controls during the reinstall.
