andrewkarl903
Sep 15, 2020Tutor
Nighthawk C7000v2 dropping connection
Our internet connection is dropping 1-4 times a day every day for the past couple months. It typically comes back within 1-2 minutes, but this is very disruptive now that we are working from home du...
Sep 16, 2020Guru - Experienced User
spectrums first response is always "its not our line, its fine". Because if its not, then they have to send out a technician and pay them to fix the line.
Many times we see issues with the line.
Log into the c7000 and get a screen snip of the cable connections page and the modem logs. This helps check the line.
Also, is it all devices that have issues when it drops, only wired devices, only wireless devices?
- andrewkarl903Sep 16, 2020Tutor
I have attached screenshots of the cable connection and event logs. Let me know if any other pictures would be helpful. Thanks for your insight.
Unfortunately can only attach 1 image at a time here it seems?
