andrewkarl903
Sep 15, 2020Tutor
Nighthawk C7000v2 dropping connection
Our internet connection is dropping 1-4 times a day every day for the past couple months. It typically comes back within 1-2 minutes, but this is very disruptive now that we are working from home du...
andrewkarl903
Sep 16, 2020Tutor
andrewkarl903
Sep 16, 2020Tutor
- andrewkarl903Sep 16, 2020Tutor
- plemansSep 16, 2020Guru - Experienced User
Your isp needs to check your line. The power levels/errors don't look bad but the cmts is sending the reset/reboot signal and having issues connecting.
