smythehe2
May 01, 2023Aspirant
Nighthawk c7000v2 Dropping Connection
I have cox and they keep telling me to contact Netgear. The firmware version I am running on is V1.03.01. Below are screen shots to my event log and cable connection. Is anyone able to tell me if thi...
May 02, 2023Guru - Experienced User
Something is in the line causing issues.
Reason why is the value of your upstream would mean you're right next to a hub. But your downstream values indicated your not that close. So something in there is acting as an attenuator but not doing that great a job because you're getting dynamic range window violations. Those violations mean you're power is going out of spec.
So if you have a signal attenuator or amplifier in line, remove them and recheck
