Dillmiester's avatar
Dillmiester
Nighthawk C7000v2 FTP Server
Hello everyone I recently purchased this router/modem to replace my Spectrum supplied combo, I want to utilize the built in FTP server to share my 4TB external hard drive over the internet and also locally in the house. I tried a few things and read some forums but nothing has solved my issues yet.
I used the built in function to create a No-IP hostname but when I try to connect to it through FTP it will say unroutable address and something about the LIST function I tried making it active instead of passive both ports are set to 21, I havent forwarded any ports. I get a prompt for the password in ftp and can access http://readyshare.routerlogin.net/shares.
Networking I have never cared for.
Please help.
    • olympos1625's avatar
      olympos1625
      NETGEAR Employee Retired
      Hi Dillmiester,
      Welcome to NETGEAR Community!
      Thank you for reaching out. We are sorry for not getting back to you immediately. Just to clarify, you just want to access your 4TB hardware which is plugged into your Cable modem locally. If yes, you do not need NO-IP for this matter. Please check this link https://kb.netgear.com/20391/ReadySHARE-USB-Storage-GUI-explained
      Please do not hesitate to let me know if you need further assistance.
      Oliver
      Community Team
        olympos1625
        Hi Dillmiester,
        Did you check if the FTP( Local) under the Readyshare page is enabled? If not please do so.
        Enable FTP Access Within Your Network File Transfer Protocol (FTP) lets you download (receive) and upload (send) large files faster. To enable FTP access within your network:
        1. Launch a web browser from a computer or mobile device that is connected to the router network.
        2. Enter http://www.routerlogin.net. A login window opens.
        3. Enter the router admin user name and password. The user name is admin. The password is the one that you specified the first time that you logged in. The user name and password are case-sensitive. The BASIC Home page displays.
        4. Select ADVANCED > USB Functions > ReadySHARE Storage. The USB Storage (Advanced Settings) page displays.
        5. Select the FTP check box.
        6. Click the Apply button. Your settings are saved.
        Oliver
        Community Team
