JeffVilla
Jun 22, 2022Aspirant
NIghthawk c7000v2 Issues with connecting 2 PS4 consoles
Hello, I recently purchased a Nighthawk c7000v2 combo model/router. For a while, i thought things were great, as it was a step up from my old motorola modem that was struggling to get wifi into the o...
- Jun 22, 2022
The 2 pieces of tech solution is not the correct course of action.
The correct course of action regarding this issue in particular is to turn off UPnP, Save changes, Power Cycle your Router, then Restart your consoles and check their network configurations.
Both are now permanently locked into NAT 2.
Had to get a level 2 tech to send me an email regarding this, and it wasnt even meant for me, it was meant for the technician i was talking to on the phone.
Hope this helps someone else down the line!~
Jun 22, 2022Guru - Experienced User
Ya I found this issue back on my CAX80. IT doesn't have NAT Filter either. SO I just had to let uPnP handle the game consoles and work with it when I had it in router mode. Only fix for this is to put the modem in to modem only mode and connect up a NG router with NAT Filter features. Set this to OPEN and both consoles will maintain same NAT level.
JeffVilla
- FURRYe38Jun 22, 2022Guru - Experienced User
Glad you got it working. Hope that works well. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
