BWyn9
Sep 23, 2021Initiate
Nighthawk C7000v2 Keeps Dropping Internet
My internet at random times cuts out anywhere from 30 seconds to 3 or more minutes. No correlation with outtages. It happens in high stress and low stress times equally. I have tried rebooting, wipin...
Sep 24, 2021Guru - Experienced User
Does it happen to all devices? Just wireless devices? Just wired?
Do you have a screen snip of the cable connections page and the event logs?
- BWyn9Sep 25, 2021InitiateIt’s the entire modem itself. Everything connected to it looses internet. The Download, Upload, and internet lights on the modem all go out and then start blinking one by one until they turn solid again and sometimes it will reaquire internet on its own and other times I will have to unplug it or even reconfigure it to get internet back.
- plemansSep 25, 2021Guru - Experienced User
Do you have the screen snip of the cable connections page and event logs?
- GdurneySep 27, 2021ApprenticeI have the same modem/router and have been experiencing the exact same issue for the past 2 months and it’s gotten progressively worse. Extremely annoying and making wifi use impossible. Haven’t been able to find a solution. Thinking it’s time to get rid of the Netgear at this point.
- FURRYe38Sep 27, 2021Guru - Experienced User
