sgnormo
Dec 28, 2022Aspirant
Nighthawk C7000v2 Keeps Dropping Internet
Happens once or twice a day where my Internet connection drops for devices that are connected by WiFi. The modem does not drop the WiFi connections, just do not have any Internet connection. ...
Dec 28, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Has a factory reset and setup from scratch been performed recently?
sgnormo
the firmware is the current firmware. things you have brought up have already been performed. So i appreciate what you listed as trobuleshooting steps.
- FURRYe38Dec 28, 2022Guru - Experienced User
Not much to go on or feed back to the questions presented so we can't help you if you don't give better feedback and post what was asked about.
