jdicicco7
May 16, 2023Tutor
Nighthawk C7000v2 losing connection frequently
Have a Nighthawk router that is about 3 years old. It keeps dropping connection, when I unplug the router and plug it back in it will allow access for maybe a hour at a time. Sometimes it brings...
- Jul 04, 2023In a delayed follow-up on my issue, a couple weeks ago, my internet just randomly started working normally without any drops. Then, Xfinity followed up thru the Twitter DMs I had initiated with them. It appears there was an issue in my area. They didn't go into specifics, but a tech looked into supposedly and the issue is fixed. Internet is running smoothly and perfectly. Thank goodness I didn't spend $$ on a new device or start (gulp!) renting from them.
jdicicco7
May 16, 2023Tutor
Here is 1 of 3 attached
jdicicco7
May 16, 2023Tutor
2 of 3
- jdicicco7May 16, 2023Tutor3 of 3
- FURRYe38May 16, 2023Guru - Experienced User
Power looks ok. A bit low but with in specs.
Correctables and Un-Correctables are all at zero which is good.
Lets take a look at the Event logs page please.
- jdicicco7May 16, 2023TutorWhere is the event log?
I see
Home
Cable connection
Wireless
Attached devices
Ready share
Guest network
