ShelboTron
May 15, 2024Aspirant
Nighthawk C7000v2 needing frequent rebooting
I just got this router/modem from Best Buy roughly 3 months ago. Everything seems to work great for a couple of weeks at a time. I have a 600mbps plan, so I definitely notice when the internet gets s...
ShelboTron
Okay so I did have the channels on auto...so I changed them to what you suggested. However it's not just my wifi that drops. It's my ethernet/direct connection to my PC that also shows the slow down. I have always had to reboot it to get it to fix again.
Here's the event log page.
| 2024-5-15, 14:12:39 | Notice (6) | WiFi Interface [wl1] set to Channel 48 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2024-5-15, 14:12:10 | Notice (6) | WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:N/A) - Reason:INTERFERENCE |
| 2024-5-15, 14:12:06 | Notice (6) | WiFi Interface [wl0] set to Channel 6 (Side-Band Channel:2) - Reason:GUI |
| 2024-5-14, 02:04:58 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| 2024-5-14, 02:04:42 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:04:33 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:04:32 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:04:30 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:04:29 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:04:27 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:04:26 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:04:15 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:04:14 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:40 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:39 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:36 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:35 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:34 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:32 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:29 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:28 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:25 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:24 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:23 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:21 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:18 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:17 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:12 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:11 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:10 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:08 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:07 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:05 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:04 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:03:03 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:02:53 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:02:52 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:02:44 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:02:44 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
| 2024-5-14, 02:02:40 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=e0:46:ee:02:53:40;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
May 15, 2024Guru - Experienced User
Lets see the cable connections log data please.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
- ShelboTronMay 15, 2024Aspirant
Sorry, I'm not really savvy with this stuff. How do I get to the "cable connection" specifically? All I can see are the event logs.
- FURRYe38May 15, 2024Guru - Experienced User
ON the modems web page there should be a menu feature called Cable Connection Status or something like that:
Under the cable connection tab, this is what it shows.
Startup Procedure Procedure Status Comment Acquire Downstream Channel 417000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 4 417000000 Hz 4.5 dBmV 42.8 dB 0 0 2 Locked QAM256 1 399000000 Hz 3.9 dBmV 40.2 dB 0 0 3 Locked QAM256 2 405000000 Hz 4.3 dBmV 42.7 dB 0 0 4 Locked QAM256 3 411000000 Hz 4.5 dBmV 42.8 dB 0 0 5 Locked QAM256 5 429000000 Hz 3.8 dBmV 42.1 dB 0 0 6 Locked QAM256 6 435000000 Hz 3.4 dBmV 41.4 dB 0 0 7 Locked QAM256 7 441000000 Hz 3.4 dBmV 41.4 dB 0 0 8 Locked QAM256 8 453000000 Hz 2.9 dBmV 40.8 dB 0 0 9 Locked QAM256 9 459000000 Hz 2.6 dBmV 40.5 dB 0 0 10 Locked QAM256 10 465000000 Hz 2.3 dBmV 40.3 dB 0 0 11 Locked QAM256 11 471000000 Hz 2.4 dBmV 40.3 dB 0 0 12 Locked QAM256 12 477000000 Hz 2.5 dBmV 40.7 dB 0 0 13 Locked QAM256 13 483000000 Hz 3 dBmV 41.3 dB 0 0 14 Locked QAM256 14 489000000 Hz 2.9 dBmV 41.3 dB 0 0 15 Locked QAM256 15 495000000 Hz 2.8 dBmV 41.4 dB 0 0 16 Locked QAM256 16 501000000 Hz 2.3 dBmV 40.8 dB 0 0 17 Locked QAM256 17 507000000 Hz 0.8 dBmV 39.4 dB 0 0 18 Locked QAM256 18 513000000 Hz 1 dBmV 39.9 dB 0 0 19 Locked QAM256 19 519000000 Hz 1.1 dBmV 39.9 dB 0 0 20 Locked QAM256 20 525000000 Hz 1.4 dBmV 40 dB 0 0 21 Locked QAM256 21 531000000 Hz 1.6 dBmV 40.4 dB 0 0 22 Locked QAM256 22 537000000 Hz 1.5 dBmV 40.3 dB 0 0 23 Locked QAM256 23 543000000 Hz 1.3 dBmV 40.2 dB 0 0 24 Locked QAM256 24 549000000 Hz 1.3 dBmV 40.1 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 19 5120 Ksym/sec 29200000 Hz 46.5 dBmV 2 Locked ATDMA 18 5120 Ksym/sec 22800000 Hz 46.1 dBmV 3 Locked ATDMA 17 5120 Ksym/sec 16400000 Hz 45.9 dBmV 4 Locked ATDMA 20 5120 Ksym/sec 35600000 Hz 47.2 dBmV 5 Locked ATDMA 21 2560 Ksym/sec 40400000 Hz 48.7 dBmV 6 Locked ATDMA 22 2560 Ksym/sec 10400000 Hz 46.5 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
