Under the cable connection tab, this is what it shows.
| Startup Procedure |
| Procedure | Status | Comment | | Acquire Downstream Channel | 417000000 Hz | Locked | | Connectivity State | OK | Operational | | Boot State | OK | Operational | | Security | Enabled | BPI+ | | IP Provisioning Mode | Honor MDD | honorMdd(4) |
| Downstream Bonded Channels |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables | | 1 | Locked | QAM256 | 4 | 417000000 Hz | 4.5 dBmV | 42.8 dB | 0 | 0 | | 2 | Locked | QAM256 | 1 | 399000000 Hz | 3.9 dBmV | 40.2 dB | 0 | 0 | | 3 | Locked | QAM256 | 2 | 405000000 Hz | 4.3 dBmV | 42.7 dB | 0 | 0 | | 4 | Locked | QAM256 | 3 | 411000000 Hz | 4.5 dBmV | 42.8 dB | 0 | 0 | | 5 | Locked | QAM256 | 5 | 429000000 Hz | 3.8 dBmV | 42.1 dB | 0 | 0 | | 6 | Locked | QAM256 | 6 | 435000000 Hz | 3.4 dBmV | 41.4 dB | 0 | 0 | | 7 | Locked | QAM256 | 7 | 441000000 Hz | 3.4 dBmV | 41.4 dB | 0 | 0 | | 8 | Locked | QAM256 | 8 | 453000000 Hz | 2.9 dBmV | 40.8 dB | 0 | 0 | | 9 | Locked | QAM256 | 9 | 459000000 Hz | 2.6 dBmV | 40.5 dB | 0 | 0 | | 10 | Locked | QAM256 | 10 | 465000000 Hz | 2.3 dBmV | 40.3 dB | 0 | 0 | | 11 | Locked | QAM256 | 11 | 471000000 Hz | 2.4 dBmV | 40.3 dB | 0 | 0 | | 12 | Locked | QAM256 | 12 | 477000000 Hz | 2.5 dBmV | 40.7 dB | 0 | 0 | | 13 | Locked | QAM256 | 13 | 483000000 Hz | 3 dBmV | 41.3 dB | 0 | 0 | | 14 | Locked | QAM256 | 14 | 489000000 Hz | 2.9 dBmV | 41.3 dB | 0 | 0 | | 15 | Locked | QAM256 | 15 | 495000000 Hz | 2.8 dBmV | 41.4 dB | 0 | 0 | | 16 | Locked | QAM256 | 16 | 501000000 Hz | 2.3 dBmV | 40.8 dB | 0 | 0 | | 17 | Locked | QAM256 | 17 | 507000000 Hz | 0.8 dBmV | 39.4 dB | 0 | 0 | | 18 | Locked | QAM256 | 18 | 513000000 Hz | 1 dBmV | 39.9 dB | 0 | 0 | | 19 | Locked | QAM256 | 19 | 519000000 Hz | 1.1 dBmV | 39.9 dB | 0 | 0 | | 20 | Locked | QAM256 | 20 | 525000000 Hz | 1.4 dBmV | 40 dB | 0 | 0 | | 21 | Locked | QAM256 | 21 | 531000000 Hz | 1.6 dBmV | 40.4 dB | 0 | 0 | | 22 | Locked | QAM256 | 22 | 537000000 Hz | 1.5 dBmV | 40.3 dB | 0 | 0 | | 23 | Locked | QAM256 | 23 | 543000000 Hz | 1.3 dBmV | 40.2 dB | 0 | 0 | | 24 | Locked | QAM256 | 24 | 549000000 Hz | 1.3 dBmV | 40.1 dB | 0 | 0 |
| Upstream Bonded Channels |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power | | 1 | Locked | ATDMA | 19 | 5120 Ksym/sec | 29200000 Hz | 46.5 dBmV | | 2 | Locked | ATDMA | 18 | 5120 Ksym/sec | 22800000 Hz | 46.1 dBmV | | 3 | Locked | ATDMA | 17 | 5120 Ksym/sec | 16400000 Hz | 45.9 dBmV | | 4 | Locked | ATDMA | 20 | 5120 Ksym/sec | 35600000 Hz | 47.2 dBmV | | 5 | Locked | ATDMA | 21 | 2560 Ksym/sec | 40400000 Hz | 48.7 dBmV | | 6 | Locked | ATDMA | 22 | 2560 Ksym/sec | 10400000 Hz | 46.5 dBmV | | 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV | | 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
