68jcode
Nov 19, 2018Initiate
Nighthawk C7000v2 network lockup trying to add Nest device
I purchased and installed (Comcast ISP) the Nighthawk AC1900 WiFi Cable Modem Router (Model C7000v2) back in May and has been working without issue until recently. A week ago, Comcast had a service ...
sanjumani
Feb 05, 2019Aspirant
I have been having identical issues. Tried all sorts of methods to solve this. No luck!
- 68jcodeFeb 05, 2019Initiate
There is a very extensive discussion on the Nest community about this problem located here. Is confirmed to be a Nest bug with the Connect device used to bridge the Yale lock with Nest. There are over 260 replies to the discussion and has been ongoing for many months without clear expectation of a fix coming. Hopefully sooner than later.
