SHABAD0O
Dec 01, 2020Tutor
Nighthawk C7000v2 Realistic WiFi Speed?
Hi everyone, and thanks for your help in advance. I just want to confirm my suspicion before I return my C7000v2, because I can't seem to find a clear answer online. I am on Spectrum's 400mbps pl...
SHABAD0O
Dec 01, 2020Tutor
Thanks for your reply. I work in television production and am regularly uploading and downloading tens or hundreds of GB of data. Regardless of my use-case, if I'm paying for 400 down, and could achieve 460 with Spectrum's hardware, I'm not going to settle for less from the Netgear hardware.
That said, I was using the D3.2 Wired modem and Wave 2 router from Spectrum. I moved the C7000v2 within feet of my PC to test if distance/walls were the issue - it still never exceeded 300mbps. These numbers are consistent across speedtest.net, fast.com, Google, etc.
Ultimately, if there's not some setting I'm clearly missing that's limiting my speed over WiFi, and/or I can't expect to see 400mbps+ with the C7000v2, I'll be returning it.
Dec 01, 2020Guru - Experienced User
I couldn't find a d3.2 modem from spectrum and "wave 2" router just means its a 2nd generatation AC. Not very specific. Maybe you mean D3.1 eMTA from spectrum? which is a docsis 3.1 device. and again, its tough to tell based off "wave 2 router. You might be comparing a quite capable router to a combo device. combo devices aren't going to have the same peak performance as having a modem seperate from the router.
As well as you weren't specific with whatt you're testing on. A wireless chipset that support 160hz wide channels is going to have twice the throughput of a 80hz devices when the C7000 only has 80hz wide channel support. Especially if the "wave 2" device supports 160hz wide channels.
Regardless you're probably maxing out the c7000.
If you're moving that much data, you should check into hardwiring in your device. Much faster speeds and less concern with congestion/data loss.
- SHABAD0ODec 01, 2020Tutor
"Regardless you're probably maxing out the c7000."
Then back it goes to Amazon. Thanks for your help.
- FURRYe38Dec 03, 2020Guru - Experienced User
I recommend that you get into a modem only option, then connect up a external wifi router, such as a Orbi AX or a RAX series router.
