SHABAD0O
Dec 01, 2020Tutor
Nighthawk C7000v2 Realistic WiFi Speed?
Hi everyone, and thanks for your help in advance. I just want to confirm my suspicion before I return my C7000v2, because I can't seem to find a clear answer online. I am on Spectrum's 400mbps pl...
Dec 01, 2020Guru - Experienced User
I couldn't find a d3.2 modem from spectrum and "wave 2" router just means its a 2nd generatation AC. Not very specific. Maybe you mean D3.1 eMTA from spectrum? which is a docsis 3.1 device. and again, its tough to tell based off "wave 2 router. You might be comparing a quite capable router to a combo device. combo devices aren't going to have the same peak performance as having a modem seperate from the router.
As well as you weren't specific with whatt you're testing on. A wireless chipset that support 160hz wide channels is going to have twice the throughput of a 80hz devices when the C7000 only has 80hz wide channel support. Especially if the "wave 2" device supports 160hz wide channels.
Regardless you're probably maxing out the c7000.
If you're moving that much data, you should check into hardwiring in your device. Much faster speeds and less concern with congestion/data loss.
SHABAD0O
Dec 01, 2020Tutor
"Regardless you're probably maxing out the c7000."
Then back it goes to Amazon. Thanks for your help.
- FURRYe38Dec 04, 2020Guru - Experienced User
I recommend that you get into a modem only option, then connect up a external wifi router, such as a Orbi AX or a RAX series router.
