ketsuekiraven
Jun 22, 2021Follower
Nighthawk C7000v2 WiFi Not Working
Overnight, my WiFi stopped working altogether. It doesn’t show up on the network lists for me to select on any of my devices. I can connect just fine on my laptop if I hardwire it. I called and had...
Jun 24, 2021Guru - Experienced User
And are you sure nobody else is pressing the wifi button to turn it off?
Has a factory reset and setup from scratch been performed?
