Razzor
Jun 08, 2020Aspirant
Nighthawk C7000v2
Just recently acquired the C7000v2 in replacement of XFINITY Dual-Band Modem. Everything is working just fine, except the XBOX. When I go online to play, it logs on just fine, etc. The problem ...
Razzor
Q1: I have not tested via hardwired.
Q2: 2.4Ghz currently, tried the 5Ghz and it was the same issue.
Q3: Approximately 20 feet maybe at most.
Jun 08, 2020Guru - Experienced User
Does this happen with just one game or all games?
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
IPv6 and Set 20/40Mhz Coexistence to 40Mhz only.
Let us know if wired ethernet does the same thing...
- RazzorJun 08, 2020Aspirant
Does this happen with just one game or all games? - Have only tested (1) so far, yet the previous modem I used was flawless right up until I switched to this one.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz. - Will do!
Any Wifi Neighbors near by? If so, how many? - Probably 4-6 on averageTry disabling the following and see:
Let us know if wired ethernet does the same thing... - Will do!
Thank you
- FURRYe38Jun 08, 2020Guru - Experienced User
Keep us posted.
