Ctrygrl
May 16, 2021Follower
Nighthawk C7000v2
I want to set up a router VPN but don't know if my Nighthawk C7000v2 is compatable with a VPN or does the fact that it is a modem/router make it incomapatable with VPNs? I know IPVanish says in their...
antinode
May 16, 2021Guru
> it incomapatable with VPNs? [...]
Pretty much, yes. The firmware in a typical DOCSIS-compatible
modem+router is off-limits to the user.
https://kb.netgear.com/000036375
> So far none of the VPN services that I have checked list my router.
I'd expect that trend to continue.
One possibility would be to configure your C7000v2 as a modem only
("bridge mode"), and get some VPN-compatible (separate) router to use
with it.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Connect Your Modem Router to a Router After Installation and
Activation".
