Wallbanger3
May 06, 2022Aspirant
NightHawk C700v2 LAN Ports stopped working
My internet provider in Xfinity. My firmware on the router is v1.03.03 I run the router as a wifi router in my home for two years and run a ethernet line to another part of the home for a direct...
May 06, 2022Guru - Experienced User
have a taken a pc/laptop and direct wired with a short 6 ft cable?
You'd be surprised at how often extended runs or home made cables will work with one device and not the next.
Usually if the ethernet is lighting up amber, it indicates a 10/100mbps connection and not a gigabit connection
- Wallbanger3May 06, 2022Aspirant
Thank you for responding. Yes I went directly in with several short run cables. 2 to 5 foot long.
- plemansMay 06, 2022Guru - Experienced User
when you hardwire in a pc/laptop to the router, what shows up in the logs?
I've plugged in a PC, a Switch and a bridged router. Nothing shows up. nothing in any LAN port is showing. The only thing that will light up is the orange light when the switch is plugged in. I'm assuming that means power but no green would mean no data transferring out.
