Wallbanger3
May 06, 2022Aspirant
NightHawk C700v2 LAN Ports stopped working
My internet provider in Xfinity. My firmware on the router is v1.03.03 I run the router as a wifi router in my home for two years and run a ethernet line to another part of the home for a direct...
Wallbanger3
Thank you for responding. Yes I went directly in with several short run cables. 2 to 5 foot long.
May 06, 2022Guru - Experienced User
when you hardwire in a pc/laptop to the router, what shows up in the logs?
- Wallbanger3May 06, 2022Aspirant
I've plugged in a PC, a Switch and a bridged router. Nothing shows up. nothing in any LAN port is showing. The only thing that will light up is the orange light when the switch is plugged in. I'm assuming that means power but no green would mean no data transferring out.
- plemansMay 07, 2022Guru - Experienced User
is it still within warranty because its sounding like a hardware failure at this point.
- Wallbanger3May 07, 2022Aspirant
unfortunately no. I have been running this router for just over 2 years.
Thank you for all of the help
