Wallbanger3
May 06, 2022Aspirant
NightHawk C700v2 LAN Ports stopped working
My internet provider in Xfinity. My firmware on the router is v1.03.03 I run the router as a wifi router in my home for two years and run a ethernet line to another part of the home for a direct...
May 07, 2022Guru - Experienced User
is it still within warranty because its sounding like a hardware failure at this point.
Wallbanger3
May 07, 2022Aspirant
unfortunately no. I have been running this router for just over 2 years.
Thank you for all of the help
- plemansMay 07, 2022Guru - Experienced User
The only other thing I can recommend trying is seeing if your ISP can re-provision in. If somethings corrupt in the firmware, they're the only ones who can push the firmware to it since combo devices aren't user upgradable.
