DonCook
Aug 21, 2022Aspirant
Nighthawk C7100V combo modem router
Just purchased this unit and discovered it “needs” a battery. Does it need the battery to function? Or is the battery only used to work if the power to the house stops?
- Aug 21, 2022
No, it does not need a battery to function. The battery is only needed to function in the event of a power outage.
Both the Quick Start Guide and the User Manual indicate the battery is sold separately.
Aug 21, 2022Guru - Experienced User
It did not come with a Battery? What does the user manual say about this?
- DonCookAug 21, 2022Aspirant
This is what the operators manual says. I read this to say the unit will run without the battery. I will set up the unit and confirm that it does not need a battery to function.
