DonCook's avatar
DonCook
Nighthawk C7100V combo modem router
Just purchased this unit and discovered it “needs” a battery. Does it need the battery to function? Or is the battery only used to work if the power to the house stops?
  • Kitsap's avatar
    Aug 21, 2022
    No, it does not need a battery to function.  The battery is only needed to function in the event of a power outage.
    Both the Quick Start Guide and the User Manual indicate the battery is sold separately.
