shawnpwilson
May 31, 2018Aspirant
Nighthawk C7100V Comcast Extreme Pro 400Mbps - not getting the speed hard wired
I just upgraded to comcast extreme pro 400Mbps and am not getting the full speed thru the modem with a direct hard wired connection.
It peeks anywhere from 250-275.via speedtest.net. comcast tech ...
vkdelta
May 31, 2018NETGEAR Employee Retired
What tool are you using to test?
Is comcast sure it is provisioned on 400 Mbps config file?
Please post your event log and connection table. If you have lot of uncorrectables, then that may explain the problem.
