ZeroTrunks
Apr 29, 2019Aspirant
Nighthawk C7100v internet drops
Greetings- I bought the C7100v nighthawk using Xfinity internet, from the recommendation of a friend and it worked great for a few months. After 3 months it started to have a deteriorating issue with...
Apr 29, 2019Guru - Experienced User
comcast technicians aren't always the best.
If you can upload your connections page from the modem connections as well as the logs that might help. This will tell us basically the connection coming in to the come and the connection back to the cmts server. Its just a snap shot but does help with troubleshooting. To much power can wreck a modem and to little can make the modem part unstable.
