mlewis6
Jun 14, 2017Aspirant
Nighthawk c7100v not allowing hopper 3 internet access
I recently switching internet providers and purchased a netgear nighthawk c7100v cable modem/router with voice. Setup went great all of our device connect and run pretty well. With the exception of ou...
mlewis6
Jul 11, 2017Aspirant
1. Xfinity. I'm not sure how to tell the fw
2. No, any other apps that use the internet will not work either.
3. No
I had dish network out to see if the issue was on their end. The swapped my hopper, and swapped out the coaxial cable within the house. Didn't fix the problem. Everything on dish end says the internet of functional until you try to use it.
I fixed the problem though. I programmed the incorrect wifi password in the hopper, so it wouldn't connect to the wifi and ran an Ethernet cable. All of the apps are functioning including Netflix.
3. No
- vkdeltaJul 11, 2017NETGEAR Employee Retired
does it still have issues or you have fixed it? sorry, I was bit confused when you say it is fixed.
Is it still connected by both WIFI and ethernet or just WIFI?
