User0
Mar 03, 2021Aspirant
Nighthawk C7100V Slow wired connection
Hello, I have a problem with my wired connection on a C7100V. I've reset all Network Adapters and talked to my ISP (Xfinity) for hours yesterday trying resolve the issue. They said it was the mod...
Mar 03, 2021Guru - Experienced User
Do you have another wired device you could test?
How are you testing? using the app? using the speedtest app?
Your power levels look pretty good but the logs tell us more.
- User0Mar 04, 2021Aspirant
Speedtest.net is how i'm testing. I do not have another device to test with. I'm about reinstall windows as I dont have alot on the PC being new anyways. Hoping that fixes it.
- plemansMar 04, 2021Guru - Experienced User
the goal is to figure out which is causing the issue.
No other hardwired device?
Or even a laptop you could borrow to test speeds?
Or potentially a usb---ethernet adapter to try?
