MTWOODLAND
Jun 25, 2020Guide
nighthawk c7100v
I'm having problems with upstream bonded channels. Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 57.0 dBmV locked atdma 3 5120 Ksym/sec 29200000Hz 57.0dBmV can get only one locked chann...
- Jun 27, 2020
Would suggest you talk with Comcast support. They control the cable side which is what you are talking about.
michaelkenward
Jun 27, 2020Guru - Experienced User
You might get better and quicker replies, and find other answers, over in the appropriate section for your device. That's probably here:
Cable Modems & Routers
