andreys
Jun 12, 2021Initiate
Nighthawk C7500 stopped broadcasting 2.4G
A few days ago I've noticed that some of my devices running on 2.4G Wifi got disconnected. I routerlogin.net to my router and can't find 2.4G setup anymore. I did factyory reset, which didn't helped....
Jun 16, 2021Guru - Experienced User
So disconnect the ISP Coax cable and the power adapter from the modem for 1 minute.
Reconnect the power adapter to the modem only.
Power ON the modem and let it come to ready.
Press the reset button for 10 seconds then release.
Connect 1 wired PC to the modem.
Walk thru the modems setup wizard.
After completing the wizard, check the Basic tab/Wireless settings page. Does 2.4Ghz appear here or seem accessible or indicate any problems?
