StephanArizona
Apr 02, 2022Follower
Nighthawk C7800 5GHz "Incorrect Password" Solved
Greetings, Wanted to share my C7800 5 GHz issue and hopefully it helps others. Purchased a new Nighthawk C7800, the 2.4 GHz worked perfectly fine but was unable to connect to the 5 GHz band. I ke...
- Apr 02, 2022
Glad you got it working thank you for letting us know. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Apr 02, 2022Guru - Experienced User
Enjoy. 📡
