2minle
Apr 02, 2021Tutor
Nighthawk C7800 and Nighthawk mesh
I have a Nighthawk C7800 modem/router. I'd like to extend coverage with a Nighthawk Mesh system, keeping my C7800 and using the mesh devices to extend coverage with a single SSID. Are these compati...
Apr 04, 2021Guru - Experienced User
If you leave the c7800 in router mode, set it with a seperate ssid from the mesh network. Then connect a few of the devices that are close/don't roam to it. It takes a little of the wireless burden off your mesh network. Its not something you have to do but it can help at times if you have devices that use a lot of bandwidth and don't move around (streamers/gaming setups).
The c7800 is a pretty powerful/solid router so you shouldn't see any performance difference in using the mesh system in router versus access point mode. If you were using an older combo device, I might not say that but I've used the c7800 and it was solid.
2minle
Jul 13, 2021Tutor
This worked like a champ. I kept my Nighthawk router as both the modem and a router. All static (non-moving devices like TVs and certain non mobile lighting devices) are connected to the Nighthawk wifi. I hung the mesh router off of the Nighthawk and placed satellites appropriately around my property. All movable devices (phones, tablets and laptops) connect to the mesh network. No break in signals or coverage now. Thanks.
- plemansJul 14, 2021Guru - Experienced User
Glad it worked well!
