mshafton
Mar 24, 2018Tutor
Nighthawk C7800 network map incomplete
Just replace c7000 with c7800. Latest firmware and latest versions netgenie installed. I have 35 devices connected and working. When I access the network map it only shows 12-15 devices. Each time I ...
mshafton
May 01, 2018Tutor
If I leave genie up long enough, it will eventually display all the devices. Takes anywhere from 2-4 hours before alll devices displayed. Netgear tech support does not consider this to be an issue. I disagree but not much I can do about it. I just don't have quick access to the map,unless I leave genie running all the time. I hate having to waste the resources to leave genie run all the time but there it is. No idea what causes this.
