Wolfs_Shield
Oct 11, 2022Aspirant
Nighthawk C7800 power cycling on roughly 2 minute intervals
AC3200 Nighthawk C7800 - other data unknown (such as firmware) Recently moved, went several months without internet, now at a place with a COX box not more than ten yards from where I want to pu...
Oct 11, 2022Guru - Experienced User
What FW version is on the modem if you can find out from the modems web page.
Can you copy and paste the Cable Connections page long enough to capture and post here in the forums?
And if you can, get the events logs page?
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Try this with the ISP coax line connected...
Might check the power adapter for voltage and amps at the tip with a meter if you have one.
Wolfs_Shield
Oct 12, 2022Aspirant
Firmware Version
V6.01.07
However, the event log keeps saying it took too long to respond and shows me nothing.
