reneegdouglas
Feb 15, 2022Tutor
Nighthawk C7800 X4S cable modem router combo
How do you turn off the router portion of this combo? This router does not provide parental controls, which we need. In order to gain parental controls we were advised by netgear IT, to purchase a c...
Feb 15, 2022Guru - Experienced User
Under Advanced tab/Administration/Router mode
With in the menu option there will be YES or NO. Select NO. This will cause the modem to reboot in to a modem only mode, disabling the router portion of the modem. Have your external Wifi router connected by it's WAN port to LAN port #1 on the back of the modem.
