JJRaven1979
Jan 13, 2023Tutor
Nighthawk CA30x Gaming Issue
When I playing games after 25-30 minutes my game randomly disconnects from the Wi-Fi -5g band. Playing on the other computer hardwired in I do not drop connection at all. Any suggestions - or...
Jan 13, 2023Guru - Experienced User
What channel are you using for 5ghz?
Avoid the dfs channels as if they detect a dfs broadcast, they have to switch off. It could be causing the drops.
JJRaven1979
Jan 13, 2023Tutor
Wifi 2.4 Channel - Set to Auto
Wifi 5g Channel 153 (see below screen shot)
- plemansJan 13, 2023Guru - Experienced User
have you tried the lower 5ghz band channels?
- JJRaven1979Jan 13, 2023Tutor
What channel would you recommend?
Try the lower 36-48
