luddite309
Jul 28, 2024Aspirant
Nighthawk CAX 80 wi fi calling issues
Hello all, first post here in the community. Just purchased the mentioned router/cable modem yesterday, for a pretty penny too. I suddenly lost the ability to make wifi calls from both my personal an...
- Jul 28, 2024
Should only need to disable SIP ALG if thats whats causing the problem and not DoS and port scan feature.
Using most current released FW version?
michaelkenward
Jul 29, 2024Guru - Experienced User
It is well hidden,and almost certainly a red herring, just a boilerplate response rather than a reasoned analysis of what is going on at our end. I posted it simply to let you know where it is. I have never come across an Android user who has suffered from that setting.
You said earlier:
Yes, the update firmware check shows no newer version.
That's not a reliable check.
What firmware version do you have on the device? A number is more useful than "the latest".
There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
Then look at the support pages for the device for the latest release listed there.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
luddite309
Jul 30, 2024Aspirant
Firmware v2.1.5.2, which seems to be the latest on the downloads page on netgear.com. Only other downloads are the app for Android and IOS and older firmware.
- luddite309Jul 31, 2024Aspirant
Just a quick follow up: Turned back on DoS and Port scan protection, and as advised wifi calling still working. Left Sip ALG and IPSec ALG disabled.
Thanks for all your help folks!
- FURRYe38Aug 03, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
