phaedruspress
Oct 27, 2021Aspirant
Nighthawk CAX30 AX2700 Cable Modem Router; One Light is Solid Amber The Other Light is Solid White
I was informed that I posted this previously in the incorrect category and while I beleive I may have gotten the answer I was looking for I thought that I would re post here just in case someone had ...
- Oct 27, 2021
Yes, you in the right forum now.
Yes, review the user manual for front LED indication behaviors. Review the modems user manual for LED indication behavior information. Amber usually means 100Mpbs connection while WHITE is 1000Mpbs. That's signifying its connecting at a 10/100mbps connection and not gigabit.
Enjoy.
Oct 27, 2021Guru - Experienced User
Enjoy.
phaedruspress
:smileyhappy:
Copy that. Thanks for the time.
- FURRYe38Oct 27, 2021Guru - Experienced User
đ
