iRyan
Jun 28, 2021Star
Nighthawk CAX30 AX2700 connection issues with DHCP and IP address reservations
I've been experiencing severe connection issues with my Nighthawk CAX30 cable modem router. If I go into my device LAN setup under advanced settings and attempt to make any DHCP IP address reservatio...
olympos1625
Dec 20, 2021NETGEAR Employee Retired
Hi wildwilly,
Good day!
Welcome to NETGEAR Community!
Thank you for reaching out. May we know who is your internet provider? When did the issue start? What is the current firmware of your Netgear modem?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
iRyan
Dec 20, 2021Star
I know you're addressing someone else's comment, but can I get a little help with my issue too? I created this post MONTHS ago, and have yet to get a response from Netgear. My issue has not gone away, and the CAX30 is in desperate need of a firmware update.
- FURRYe38Dec 20, 2021Guru - Experienced User
You might send olympos1625 a PM to get there attention...
iRyan wrote:
I know you're addressing someone else's comment, but can I get a little help with my issue too? I created this post MONTHS ago, and have yet to get a response from Netgear. My issue has not gone away, and the CAX30 is in desperate need of a firmware update. - olympos1625Dec 21, 2021NETGEAR Employee Retired
Hi iRyan,
We are sorry for the inconvenience this has caused you. We would like to endorse you to NETGEAR Level 2 support team for a callback. Please DM the following information:
Name:
Email:
Phone:
Preferred schedule (atleast 2 days ahead)
Timezone:
Device S/N:
Firmware version of the CAX30:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
- dharris3May 05, 2022TutorI am having this exact same issue. Please update with resolution. Latest firmware offered no relief to the issue.
- iRyanMay 07, 2022Star
dharris3- I was never able to resolve the issue with reserving IP addresses in DHCP. Someone suggested to me a few months ago that manually assigning an NTP server to keep the CAX30's internal clock updated worked for them, but doing that didn't fix the issue for me personally. I gave up trying to reserve IP addresses for my devices and eventually ended up doing a factory reset on the CAX30, and now I just let the DHCP auto-assign them all so I can have working internet.
