iRyan
Jun 28, 2021Star
Nighthawk CAX30 AX2700 connection issues with DHCP and IP address reservations
I've been experiencing severe connection issues with my Nighthawk CAX30 cable modem router. If I go into my device LAN setup under advanced settings and attempt to make any DHCP IP address reservatio...
iRyan
Dec 20, 2021Star
I know you're addressing someone else's comment, but can I get a little help with my issue too? I created this post MONTHS ago, and have yet to get a response from Netgear. My issue has not gone away, and the CAX30 is in desperate need of a firmware update.
olympos1625
Dec 21, 2021NETGEAR Employee Retired
Hi iRyan,
We are sorry for the inconvenience this has caused you. We would like to endorse you to NETGEAR Level 2 support team for a callback. Please DM the following information:
Name:
Email:
Phone:
Preferred schedule (atleast 2 days ahead)
Timezone:
Device S/N:
Firmware version of the CAX30:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
- dharris3May 06, 2022TutorI am having this exact same issue. Please update with resolution. Latest firmware offered no relief to the issue.
- iRyanMay 08, 2022Star
dharris3- I was never able to resolve the issue with reserving IP addresses in DHCP. Someone suggested to me a few months ago that manually assigning an NTP server to keep the CAX30's internal clock updated worked for them, but doing that didn't fix the issue for me personally. I gave up trying to reserve IP addresses for my devices and eventually ended up doing a factory reset on the CAX30, and now I just let the DHCP auto-assign them all so I can have working internet.
- FURRYe38May 08, 2022Guru - Experienced User
Did you try setting a small default DHCP IP address pool size? Try 192.168.1.100 to .200 and see if IP Reservations work for you?
