iRyan
Jun 28, 2021Star
Nighthawk CAX30 AX2700 connection issues with DHCP and IP address reservations
I've been experiencing severe connection issues with my Nighthawk CAX30 cable modem router. If I go into my device LAN setup under advanced settings and attempt to make any DHCP IP address reservatio...
May 08, 2022Guru - Experienced User
Did you try setting a small default DHCP IP address pool size? Try 192.168.1.100 to .200 and see if IP Reservations work for you?
iRyan
May 08, 2022Star
Actually, that was one of the very first things that I tried and that made no difference. I'm confident this must be some sort of firmware issue, so it would be really nice if Netgear would release a firmware update for the CAX30. Especially considering the last update was almost a full year ago!
- KTVonATVAug 08, 2022Aspirant
Do we have any updates for this issue? I have been having the DHCP problem since I purchased the CAX30 in Dec 2021. Netgear sent me out a new router in Mar 2022 with the exact same problem.
I have tried the NTP setting.
I tried assigning IP addresses. The router ignores the assignment and just assigns an IP of its choosing.
Rebooting doesn't fix it for long.
