Frustratedtech's avatar
Feb 22, 2023
nighthawk cax30/ ax2700 dhcp and wifi not working.
Nighthawk cax30 stop working out of the blue.  It no longer connects to IPV4 using DCHP. It also doesn't like to function using 5ghz.  Will connect using ipv6 but won't use internet correctly. I have factory reset several times and also set the firmware back one level. None of the suggestions from netgear have helped.
