ljmagyar
Dec 09, 2021Star
Nighthawk CAX30 AX2700 Drops network connection randomly
The actual model number of my router isn't shown in the drop down and it wont let me enter it manually. I have a Nighhawk AX6 CAX30 AC2700 router. I bought it new on October 13 2021 to save $15/mon...
Roberden
Dec 19, 2021Tutor
I just installed your same NETGEAR modem/router three days ago (CAX30 AX2700 AX6). Yesterday and today I've had wifi drops, same as you. Ethernet connected devices work well, wifi devices connect to the router but the signal is not passed out from the router. The 2.4 and 5 bling but devices 'cannot connect'. The only way to remedy this is by restting or power cycling the modem/router.
Have you gotten a solution?
