ljmagyar
Dec 09, 2021Star
Nighthawk CAX30 AX2700 Drops network connection randomly
The actual model number of my router isn't shown in the drop down and it wont let me enter it manually. I have a Nighhawk AX6 CAX30 AC2700 router. I bought it new on October 13 2021 to save $15/mon...
Roberden
Dec 19, 2021Tutor
I just installed your same NETGEAR modem/router three days ago (CAX30 AX2700 AX6). Yesterday and today I've had wifi drops, same as you. Ethernet connected devices work well, wifi devices connect to the router but the signal is not passed out from the router. The 2.4 and 5 bling but devices 'cannot connect'. The only way to remedy this is by restting or power cycling the modem/router.
Have you gotten a solution?
ljmagyar
Dec 19, 2021Star
No. Netgear tech support only suggested "reset the device". If it happens again they will issue an RMA.
- FURRYe38Dec 19, 2021Guru - Experienced User
đ
Please give feedback to the other questions presented.
- RoberdenDec 19, 2021Tutor
FURRYe38 wrote:đ
Sorry, but could you please be more specific regarding the 'other questions'. Not sure what you are referencing..
- FURRYe38Dec 20, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
