ljmagyar
Dec 09, 2021Star
Nighthawk CAX30 AX2700 Drops network connection randomly
The actual model number of my router isn't shown in the drop down and it wont let me enter it manually. I have a Nighhawk AX6 CAX30 AC2700 router. I bought it new on October 13 2021 to save $15/mon...
ljmagyar
Dec 19, 2021Star
No. Netgear tech support only suggested "reset the device". If it happens again they will issue an RMA.
Dec 19, 2021Guru - Experienced User
đ
Please give feedback to the other questions presented.
- RoberdenDec 19, 2021Tutor
FURRYe38 wrote:đ
Sorry, but could you please be more specific regarding the 'other questions'. Not sure what you are referencing..
- FURRYe38Dec 20, 2021Guru - Experienced User
Please post a copy and paste of the modems connection status page.
- RoberdenDec 20, 2021Tutor
Also, FYI, I just had to reset/reboot the router. All WIFI enabled devices show being connected to the router but without internet access. I changed channels (WIFI) on both bands but to no avail. THis AX2700 is less than a week old.
