ljmagyar
Dec 09, 2021Star
Nighthawk CAX30 AX2700 Drops network connection randomly
The actual model number of my router isn't shown in the drop down and it wont let me enter it manually. I have a Nighhawk AX6 CAX30 AC2700 router. I bought it new on October 13 2021 to save $15/mon...
AnnoyedCAX30Uzr
Jan 05, 2022Aspirant
Is there some kind of FIX to this that actually works?
Every single day I have to re-boot the blasted thing - and then it may or may not work! I only have my cell phone and Amazon FireTV connected, so it cannot possibly be muddled up because it's got too many devices since it supposedly is "Designed to Handle 35+ Devices at Once"
I just want to check my email or the news headlines, make the odd Amazon shopping search on my cellphone and/or watch a simple streamed movie from my service. Is that too much traffic?? I end up having to use my mobile data most of the time and that is adding up like crazy.
I purchased this CAX30 AX2700 - Wi-Fi 6 Router and Cable Modem All In One - from Costco on October 5, 2021
I'm having to type this question with my computer at work. Frustrating.
I would NEVER recommend this modem router to anyone. ESPECIALLY at a $250 wallop!
- ljmagyarJan 06, 2022Star
AnnoyedCAX30Uzr said"
"I purchased this CAX30 AX2700 - Wi-Fi 6 Router and Cable Modem All In One - from Costco on October 5, 2021"
Hmm... I got mine from a Costco on Oct 13, 2021... is this a special model made for COSTCO?
Yesterday, Xfinity came out again and re-checked everything. All the signals were good at the tap and good at the house. they were measuring 5 to 6 dBmV on all channels - which is an improvement from the 4 to 5 it was before I complained about a weak signal for the 4th time.
The tech then came in the house and we ran further diagnostics, not finding an issue with the signal strength.
He called the tech help desk and then asked them to provision the modem... something I had not heard (doesnt mean it didn't happen) them do before.
I work from home - for the next 2 hours I continually dropped connection. All at once, I got a text from Xfinity -
266278:XFINITY UPDATE
Our processes have completed for your Xfinity services. Please reply Y to confirm that your service is restored and issues have subsided or N to connect with an agent. Txt Help or Stop. Msg&DataRatesMayApply 11:25 AM===========================================
From the time if that text, I had not had a disconnect. Sometime near 3PM I got a call from Xfinity asking me if everything was ok. I told them I was reserving judgement.
Up to the tech's visit yesterday, the disconnects had been increasing in frequency to the point of being impossible to stream TV or stay connected to my VPN for work. From the data, it appears that Xfinity boosted the signal strength from before and did the PROPER provisioning this time.
Here's what the connection looks like this morning.
<tabindex=-1>Startup Procedure</tabindex=-1> Procedure Status Comment Acquire Downstream Channel 507000000 Hz Locked Connectivity State OK Registration Complete Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode Honor MDD IPv6 only <tabindex=-1>Downstream Bonded Channels</tabindex=-1> Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectabables 1 Locked 256 QAM 5 507000000 Hz 6.5 dBmV 42.8 dB 0 0 2 Locked 256 QAM 1 477000000 Hz 6.2 dBmV 42.5 dB 0 0 3 Locked 256 QAM 2 483000000 Hz 6.1 dBmV 42.6 dB 0 0 4 Locked 256 QAM 3 489000000 Hz 6.3 dBmV 42.8 dB 0 0 5 Locked 256 QAM 4 495000000 Hz 6.1 dBmV 42.5 dB 0 0 6 Locked 256 QAM 6 513000000 Hz 6.1 dBmV 42.6 dB 0 0 7 Locked 256 QAM 7 519000000 Hz 6.0 dBmV 42.4 dB 0 0 8 Locked 256 QAM 8 525000000 Hz 6.2 dBmV 42.5 dB 0 0 9 Locked 256 QAM 9 531000000 Hz 6.4 dBmV 42.6 dB 0 0 10 Locked 256 QAM 10 537000000 Hz 6.5 dBmV 42.6 dB 0 0 11 Locked 256 QAM 11 543000000 Hz 6.3 dBmV 42.5 dB 0 0 12 Locked 256 QAM 12 549000000 Hz 5.9 dBmV 42.5 dB 0 0 13 Locked 256 QAM 13 555000000 Hz 5.9 dBmV 42.4 dB 0 0 14 Locked 256 QAM 14 561000000 Hz 6.1 dBmV 42.4 dB 0 0 15 Locked 256 QAM 15 567000000 Hz 6.3 dBmV 42.4 dB 0 0 16 Locked 256 QAM 16 573000000 Hz 6.2 dBmV 42.4 dB 0 0 17 Locked 256 QAM 17 579000000 Hz 6.2 dBmV 42.4 dB 0 0 18 Locked 256 QAM 18 585000000 Hz 6.2 dBmV 42.4 dB 0 0 19 Locked 256 QAM 19 591000000 Hz 6.2 dBmV 42.4 dB 0 0 20 Locked 256 QAM 33 453000000 Hz 6.2 dBmV 42.8 dB 0 0 21 Locked 256 QAM 34 459000000 Hz 6.2 dBmV 42.8 dB 0 0 22 Locked 256 QAM 35 465000000 Hz 6.3 dBmV 42.8 dB 0 0 23 Locked 256 QAM 36 471000000 Hz 6.1 dBmV 42.7 dB 0 0 24 Locked 256 QAM 38 429000000 Hz 6.5 dBmV 43.0 dB 0 0 25 Locked 256 QAM 39 435000000 Hz 6.5 dBmV 42.9 dB 0 0 26 Locked 256 QAM 40 441000000 Hz 6.1 dBmV 42.8 dB 0 0 27 Locked 256 QAM 41 447000000 Hz 6.2 dBmV 42.8 dB 0 0 28 Locked 256 QAM 42 405000000 Hz 6.4 dBmV 43.0 dB 0 0 29 Locked 256 QAM 43 411000000 Hz 6.2 dBmV 42.9 dB 0 0 30 Locked 256 QAM 44 417000000 Hz 6.1 dBmV 42.7 dB 0 0 31 Locked 256 QAM 45 423000000 Hz 6.2 dBmV 42.9 dB 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 <tabindex=-1>Upstream Bonded Channels</tabindex=-1> Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 35600000 Hz 41.3 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 29200000 Hz 41.5 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 22800000 Hz 40.3 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 16400000 Hz 39.5 dBmV 5 Locked ATDMA 5 5120 Ksym/sec 39600000 Hz 42.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV <tabindex=-1>Downstream OFDM Channels</tabindex=-1> Channel Channel ID Indicator Subcarrier Zero Frequency Active Subcarrier Number Range Total Codewords Uncorrectable Codewords 1 37 Non-Primary 617.6 MHz 1108 ~ 2987 252358238 0 2 0 Other 0 MHz 0 ~ 0 0 0 <tabindex=-1>Upstream OFDMA Channels</tabindex=-1> Channel UpstreamIsMuted Ranging Status Subcarrier Zero Frequency Active Subcarrier Number Range Symbols Per Frame Tx Power 1 Other 0 MHz 0 ~ 0 0 0 dBmV 2 Other 0 MHz 0 ~ 0 0 0 dBmV Extended Upstream Transmit Power Enable Extended Upstream Transmit Power Current System Time: 2022-01-06 07:09:33System Up Time: 20:14:53
- FURRYe38Jan 12, 2022Guru - Experienced User
Any progress on this?
- ljmagyarJan 12, 2022Star
In my case, no. it worked well for a few days and now is back to dropping. It appears that when the downstream signal gets below 5dBmV the modem wants to reset to get better signal strength. It is absurd.
In the last 12 hours it has rebooted at least twice.
- MN_MarkJan 12, 2022Aspirant
If you look around the posts here you will find that many people are having trouble with this reouter if almost anything is changed from the defaults (Including SSID, Guest network on/off) It seems like it is a processor/memory thing in that it gets really slow with the nighthawk app and/or web interface. DHCP stops working, so you get IP configuration errors when trying to connect. I spend a whole day troubleshooting with Comcast, and then went so far as to buy a new one at Costco. (Wonder why they are on sale?) The new one worked great out of the box, got it provisioned and tested by Comcast, all OK. Changed the SSID - Stopped working. Did a factory reset, back to working. Limping along now wit the NetgearXX SSID, but at least it works.. Bottom line, if you are having issues, do a factory reset and don't touch anything. Bet your problems will go away.
- AnnoyedCAX30UzrJan 12, 2022Aspirant
No progress for me... I actually made it to 4 days before having to REBOOT AGAIN, but same issue.
And, I do NOT change (and have NOT changed) any of the settings. I've done the "reset" thing a couple of times (poke a paperclip end into the tiny hole, per troubleshooting suggestion), so all my settings are and have been the same out of the box. It seems that no matter what settings a person uses there will be issues. Grrr.
- ljmagyarJan 13, 2022Star
same. i tried the new channels and lasted about 4 hours before it reboot itself.
