ljmagyar
Dec 09, 2021Star
Nighthawk CAX30 AX2700 Drops network connection randomly
The actual model number of my router isn't shown in the drop down and it wont let me enter it manually. I have a Nighhawk AX6 CAX30 AC2700 router. I bought it new on October 13 2021 to save $15/mon...
Jan 12, 2022Guru - Experienced User
Any progress on this?
AnnoyedCAX30Uzr wrote:
Is there some kind of FIX to this that actually works?
Every single day I have to re-boot the blasted thing - and then it may or may not work! I only have my cell phone and Amazon FireTV connected, so it cannot possibly be muddled up because it's got too many devices since it supposedly is "Designed to Handle 35+ Devices at Once"
I just want to check my email or the news headlines, make the odd Amazon shopping search on my cellphone and/or watch a simple streamed movie from my service. Is that too much traffic?? I end up having to use my mobile data most of the time and that is adding up like crazy.
I purchased this CAX30 AX2700 - Wi-Fi 6 Router and Cable Modem All In One - from Costco on October 5, 2021
I'm having to type this question with my computer at work. Frustrating.
I would NEVER recommend this modem router to anyone. ESPECIALLY at a $250 wallop!
ljmagyar
Jan 12, 2022Star
In my case, no. it worked well for a few days and now is back to dropping. It appears that when the downstream signal gets below 5dBmV the modem wants to reset to get better signal strength. It is absurd.
In the last 12 hours it has rebooted at least twice.
- MN_MarkJan 12, 2022Aspirant
If you look around the posts here you will find that many people are having trouble with this reouter if almost anything is changed from the defaults (Including SSID, Guest network on/off) It seems like it is a processor/memory thing in that it gets really slow with the nighthawk app and/or web interface. DHCP stops working, so you get IP configuration errors when trying to connect. I spend a whole day troubleshooting with Comcast, and then went so far as to buy a new one at Costco. (Wonder why they are on sale?) The new one worked great out of the box, got it provisioned and tested by Comcast, all OK. Changed the SSID - Stopped working. Did a factory reset, back to working. Limping along now wit the NetgearXX SSID, but at least it works.. Bottom line, if you are having issues, do a factory reset and don't touch anything. Bet your problems will go away.
- ljmagyarJan 12, 2022Star
i did that with Netgear tech support once - but had to set up port forwarding. the SSID is stock. Do you think even adding port forwarding would cause it to crash?
To be honest, I think so. I have seen posts where SSID and Guest network on/off are documented. It seems like the firmware is really unstable. Do a reset and see if it works and then add one thing at a time untill it breaks. I don't use port forwarding..
