ljmagyar
Dec 09, 2021Star
Nighthawk CAX30 AX2700 Drops network connection randomly
The actual model number of my router isn't shown in the drop down and it wont let me enter it manually. I have a Nighhawk AX6 CAX30 AC2700 router. I bought it new on October 13 2021 to save $15/mon...
ljmagyar
Jan 12, 2022Star
i did that with Netgear tech support once - but had to set up port forwarding. the SSID is stock. Do you think even adding port forwarding would cause it to crash?
MN_Mark
Jan 12, 2022Aspirant
To be honest, I think so. I have seen posts where SSID and Guest network on/off are documented. It seems like the firmware is really unstable. Do a reset and see if it works and then add one thing at a time untill it breaks. I don't use port forwarding..
